Cub 128 won't spark
New battery, new wiring harness (Thanks forum member Mlamar), new solenoid, new ignition switch, new coil, and a new spark plug. Does anyone have any idea where I should start? It turns over very well, but doesn't fire.
I would start with checking to see if you have 12VDC at the (+) positive terminal to the Ignition Coil, when measured to Chassis Ground (or Battery negative terminal).
See Kohler K series Ignition ..... http://www.onlycubcadets.net/forum/showthread.php?t=27
You do know the difference between amps and voltage correct???? Did you mean a volt meter???
If the "electric measuring thing" has a setting for DC volts, use that and report back the findings.
Just had amps, if I can find my test light, I'll let you know what happens.
Like I said before, do you have 12 VOLTS as previously described...???
I don't see any mention of points or condenser in the original post.
Roland is asking how many volts you have, not if you have any but rather HOW MUCH--you need something other than a test light to answer his question. Basic Meters are pretty cheap these days and quite handy---certainly recommend this tool.
Have you tried just running a fine grit piece of sandpaper between the points?
