169 leaking oil
Good evening all. Seems that the 169 has developed an oil leak as of recent and I'm not sure how it came to be or what is causing it.
In the first pic it is welling or weeping out of circle in the block that my finger is pointing to. In the second pic it seems theres an additional leak at the gov/throttle linkage. You can see a drip at the bottom of the linkage. Its a steady leak and it's leaking onto the points cover. Please help! Ps I forgot to add the only thing I have done was remove the OEM breather and guts and install the Kirk breather with a new gasket....were some of the guts supposed to remain? |
You did something wrong. Either you installed it wrong, or something. I am certain that changing the breather is the source of the leak. Your crankcase is pressurizing. I don't know why you need a different breather anyway. The original style is fine. Just put it back on. |
My mechanic put it on when he installed the new cork gasket for the hydro but that's what I am thinking. I know the breather is getting the pressure out as I feel the pressure at the end of the hose but yeah it sure is weeping alot. I'll have to take it off myself and reexamine. I bought the breather along with the points saver, ignition coil and wire from Kirk
Point Savers are a waste of money too.....
Points very seldom wear out. Plus, setting timing is easy and only needs to be done if you A.) Filed the points. Or B.) Replaced the points, or otherwise removed them to work on the motor. |
Either way, the original factory breather and points were proven for many years as working fine as is/was. Waist of money to me, but it's your money, your tractor.
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
Maybe the new cover restricts the airflow from the crank case enough that it forces the engine to find worn parts to breath through. Putting the old cover back on should confirm this.
The Collection, so far: Cub Cadet 100(x2), 125(x2), 123(x2), 70, 71. Adding more when I can find them. |
Did the oil leak start immediately after the repair work or has it been like 6 months and then starts leaking? Your opening statement alludes that the leak appeared and increased over a period of time. How long would an INCORRECT breather installation take to start pushing oil out? I don't know either, but I would tend to think that it would be sooner rather than later. |
I would attribute this to the breather. I just had the breather installed and this was the first time running it since installation. Something isn't right and causing blow by
He already did.....
Try installing the breather guts first. Make sure the drain hole in the OEM breather assembly is towards the bottom. While you have the breather assembly open it would be a good time to check tappet clearance.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
