Kohler kt 17 valve question
I have a series II motor that I am going to pull the valves out,clean and put back in. I know to make sure I put them back in the proper place they came from (exhaust or intake)My question is does the valve have to be in the same position as when it was taken out?Also what works best to remove carbon from valve chambers?
Just put them back in the cylinder they were removed from. They can rotate by themselves when the engine is running. I can't remember if the KTs have exhaust valve rotators or not. A brass wire wheel, plastic scraper, and razor blade work good to remove carbon.
Your probably going to want to buy a valve spring compressor to get the valve in and out. That job would be a real bear without one. Search e-bay for a small engine valve spring compressor and you'll find them. As far as putting the keeper back in, I turned the engine so that the valves were vertical and that will allow the keepers to fall into place.
AJ
1980 [COLOR="Red"][/COLOR]482- Stock 1981 [COLOR="Red"][/COLOR]582- Mag18, Sleeve Hitch, Spring assist 1979 [COLOR="Red"][/COLOR]682- Mag18, Sleeve Hitch, Spring Assist, #1 Tiller 1980 [COLOR="Red"][/COLOR]782- Mag18, Sleeve Hitch 1983 [COLOR="Red"][/COLOR]982- Stock, Fully Optioned |
Thread Tools | |
Display Modes | |
