Any secrets to swapping Lift Valve?
After a couple weeks of trying to unstick the lift valve assembly on my Quietline, I give up and have located a good used unit. What am I up against when I remove the hydraulic lines? Is oil going to fly everywhere? Will there be air introduced to the system? Will I need to add oil and purge the air? If so, how so I do this? I did a search in the technical library but could not find out answers to these questions. Maybe I am thinking too much but it seems to me, unless the new lift valve is full of oil, there will be air introduced and that can't be good. If anyone can help me out I'd appreciate it.
Rich |
You'll lose some oil, but not an appreciable amount. Simply operating the hydraulics after installing the valve will work out any air trapped in the system.
I have a suggestion. if you are taking the valve out to replace it, put it in a vice, and hit the valve with a hammer. if it breaks, get a new one like you planned. if it works, you saved a bit of money and time. just my $.02
Tyler Chiliak. Southeast Alberta Canada. My dad and I own, 1650, , 1450, 1250, 1250, 1200, 982, 782, 149, 149, 149, 128, 128, 123, 100, 100. Also a 1310, 1500, and 2 1600 IHC trucks. |
Just my luck, the day the replacement valve arrives my stuck valve breaks free. Good ol' PB Blaster.
Hehe! good to hear you got it working. now do you want to send the spare valve up here???
I sent you a PM
Thread Tools | |
Display Modes | |
