Greg Rozar AKA- CubDieselFan
Old 10-26-2017, 11:01 PM
wayne13 wayne13 is offline
Default Dozer blade
I have a dozer blade I got with my 149, I am wanting to use it on my 1450. I know that it fits because I asked already. And I have looked at the manual on this site for the model blade #190-401-100. Mine must be different because there are no anchor plates on the 149 and it looks different. What I want to know is do I have to take anything off of the 149 to use the blade on the 1450? Pictures to show what my blade mounts look like and should there be a model tag on it someplace?
Old 10-26-2017, 11:17 PM
That blade will go on the 1450. Nothing on the 149 to remove. No idea what "anchor plates" are. Don't know why you can't get it on, it fits. You don't have a mower subframe on the 1450 do you? It has to come off if you do. No tag on the blade.
Old 10-27-2017, 06:36 AM
Like Jon said that blade will go right on your 1450.
The part number you have there for the blade is for a super cub cadet with the Haban 54" blade. You don't need the anchor plates, they are for the super cub.
Old 10-27-2017, 07:31 AM
The 190-401 Dozer Blade was NEVER intended for the 1x8/9 or Quietline series tractors.
Roland Bedell
Buy: Made in the USA
Old 10-27-2017, 07:48 AM
Where did you come up with the number 190-401-100,
would be the question?
Have you had the push blade on your 149 and
did it fit properly ?
if so just put it on your 1450.
Old 10-27-2017, 08:28 AM
I didn't pay any attention to the number for the blade he posted. I just looked at the pics of his blade. I like pictures.
OP: If you did look up the 190-401 blade, how did you not notice it doesn't look anything like the one you have? Not even close to made the same way.
Old 10-27-2017, 09:12 AM
ironman's Avatar
ironman ironman is offline
Wayne13, here is a link to the manual for the blade you have pictured. Hopefully it answers all you questions.
http://ccmanuals.info/pdf/Front%2042...l%20Manual.pdf
Old 10-27-2017, 09:34 AM
The information on the 42/54 IH Dozer blades is located right here in our Technical Library section..... http://www.onlycubcadets.net/forum/showthread.php?t=15335
Roland Bedell
Old 10-27-2017, 09:36 PM
I found the dozer blade manual on this web site the number I posted was on the cover of the manual. I don't know if it is a part number for the manual, the dozer blade or both? The 149 was non running when I got it so I never tried to put the blade on it. I got the 1450 to run but it needs more work to be useable. I need to sell the 149 so I wanted to make sure I had any parts off of it that I would need. Thanks to all for the info and links.
