#31
Well, when it comes to dirty hydro units, yours is up there with some of the worst. I know you are looking an engine, but while you are this far along with the rear, take a look at your trunion springs. Also research threads on rebuilding trunions. Oh, now is a good time to work on the steering column since it is real easy to get to. Be careful, when you take when this far apart, that brown truck will be coming to your house 2-3 times a week, just saying.
#32
Not to mention planning your days around tracking numbers.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower IH Cub Original with deck #2 cart GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck |
#33
I know about that , between my 7.3 diesel and my onan 10CW generator I see it alot. On another note, is it normal to not be able to disengage the pto without the mower deck on? I have it off waiting for a new belt and no matter how i adjust it the pto keeps spinning. I'm thinking maybe with the mower deck and belt hooked up it may be enough resistance to stop it.
1971 IHC Cub cadet 106 1982 IHC Cub Cadet 682 (looking for engine) |
#34
#36
It's not uncommon for the mechanical PTO to continue to spin when there's no load on it.
#37
Just what I was hoping to hear, thank you
#38
Matter of fact the PTO should stay in the "ON" position when not in use (no attachment needing it installed). Otherwise, you will tear up the brass button.
#39
Well I finally tore the KT17 down out of the 682 last night and found the governor gear/weights came apart and that's what got ejected from the side of the block when the piston came back and smashed one of the weights into the case. It makes sense now what the previous owner told me happened, he was mowing his yard and then he heard a pop and then the engine went full throttle. He said he tried to cut it off but it over sped and threw a rod before he could. All the internals look good except for some scarring on the rod cap where the governor fly flyweight contacted it . sorry for no pics I will try and get some up soon.
#40
I’m betting the governor gear shaft came out of its bore.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240 |
