782 rear end going out
My 782 rear is starting to make all kinds of noise and is starting to get slow I changed the oil and the filter and still having the issue. Do they make a replacement rear for these tractors or is it better to part ways with it
What kind of noise is it making? Is it a whining sound? What filter did you use?
Is it the differential that is making noise or the hydro assembly?
The setup you have is pretty sturdy and rarely gives trouble, unless you are abusing it or tractor pulling with it. If you go into some detail as to the what and when the noise occurs we might be able to help you. If you have a nice 782, it is worth fixing by all means. |
It's a whining noise and I used cub cadet filter. When it's about half throttle it'll barely move
It sounds like the hydro.
When you pulled the cover to drain the oil, was it clean or sludged up, was the oil milky? was there metal particles in the housing Was the filter/oil changed recently? |
Does it work better in one direction then the other?
A little thick some Metallic better forward than reverse
Did you change the oil & filter recently to correct the problem you have now?
Or was it changed a while back in time as routine maint. if a while back, change the filter. |
It was doing it before and changed the filter the other night and it's still Doug it
Sounds like the hydro failing, not the "rear end" going out. Rear end would refer to the differential, not the hydrostatic transmission.
You can investigate further, or buy a good used. Ported hydro's can be purchased for about $100-$150 depending on the guy selling. Avoid the ones over $200. Those people are insane. Put up a wanted ad on this site, watch ebay, check with the our sponsors at the top of the page, or take a peek at craigslist. In your case it is probably best just to start over than to try and fix it. However, it may be repairable if you want to attempt it, state that. But we are going to need to hear the noise it's making, and you are going to have to do some diagnostic work. |
