Greg Rozar AKA- CubDieselFan
Old 04-15-2009, 12:26 PM
drivadesl drivadesl is offline
Default Removing Hydro Lever
I'm having a tough time removing the lever from the splined shaft to which it is attached. I have it so it moves maybe an eighth inch up and down on the splines, but then stops like it is hitting something. I removed the set screw before starting, and at first had no movement whatsoever. Hit it with WD40 and tried prying but theres no real easy way I can see to force it off. Must be a burr or something in the way. I'm not sure if its possible, but I'm going to try removing the shaft from the dash tower and then see if I can get the lever off from the bench. Anyone have any other tips or suggestions?? Thanks in advance.
Old 04-15-2009, 12:38 PM
drivadesl
Try using PB Blaster instead of WD40. I have found this is way better.
Spray in the set screw hole and allow it to soak & work. Then lift and wiggle at the same time. A lot of people have had good results with this procedure.
Roland Bedell
Buy: Made in the USA
Old 04-15-2009, 06:26 PM
Thanks, though based on the feel, I don't think its rust thats holding this on. It slides up/down with a push, than stops abruptly. I'm thinking a burr where the set screw thread in. If I can get the whole rod out, I can put it in a vise and give it a little motivation to come off with a hammer. As it is now, all I can do is put a vise grip on the rod, and try to pry it off using that as the fulcrum. I don't want to damage the lever casting in the process.
Old 04-15-2009, 07:53 PM
OK, I stand corrected. Never should have doubted all your experience RB. :biggrin2.gif: I disconnected the mounting bolts which allowed me to raise the lever/rod. This provided some room to hit it with a wooden mallet from below. That, and some PB seemed to get the job done. So thanks for the great suggestion RB......Now, how do you get the steering wheel off??? I removed the nut off the threaded shaft, but she don't want to move. Tried a wheel puller, only mangled up some more, an already mangled steering wheel. More PB and a hammer maybe????
Old 04-15-2009, 08:11 PM
Jim H.'s Avatar
Jim H. Jim H. is offline
If you go to technical library you will find this and pics courtsy of our own RB.
Steering Wheel Removal
Obtain a 5/8” – 18 x 4” bolt and nut. I get Grade 8.
Sit in the seat of your Cub Cadet Tractor. Place you legs in such a fashion, that you can apply upward pressure with your knees on the under side of the Steering Wheel.
Screw the nut onto the bolt, about 1/2 way. Screw on that assembly, onto the Steering Shaft until it bottoms out. Inspec, that the nut from the above assembly, is NOT resting on the Steering Wheel Hub. There has to be a gap here.
While applying upward pressure with your knees, give the Grade 8 bolt a few whacks with a big hammer. This jarring should release the steering wheel from the shaft..
This is one way of removing the Steering Wheel. There are other methods also. Special fabricated pullers have been used with success.
CC Models: 100, 105, 129, 1450, & 784
Every time I find the key to success, someone changes the lock
