Greg Rozar AKA- CubDieselFan
Old 11-17-2017, 11:27 AM
MattC's Avatar
MattC MattC is offline
Default Cub 127 Hydrostatic Issue
Hello all,
I recently added a Cub 127 to my growing fleet. The tractor ran fine the first couple of times I used it. The only issue I had is that it wanted to creep when in neutral.
I didn't want the tractor to start creeping when I turned it on, so I flipped the tow valve up first. After starting the tractor I put the valve back down. My problem is that the valve did not engage the hydrostatic. I am now stuck, unable to move the selector out of neutral.
Is this a common problem? Am I overlooking something simple? I did a quick search and didn't find much on the issue.
Current Fleet: 100, 126, 147, 128, 1450, 1650
Old 11-17-2017, 11:36 AM
Is the brake on? The lever won't move with the brake on.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-17-2017, 11:48 AM
IF.....everything is original to the Tractor, then it should have the Check (or Relief) valve as seen on the right.
The possibility exists that if the "plunger" is stuck in the down position, you would experience what you are having.
You can use some penetrate (ie: PB Blaster, Kroil, etc) and spray the plunger area. Make sure the plunger moves "freely".
Roland Bedell
Buy: Made in the USA
Old 11-17-2017, 11:50 AM
Just curious how the check valve's would effect the lever in the dash moving?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-17-2017, 11:55 AM
I was assuming he was referring to the handle on the Tunnel Cover.
Roland Bedell
Old 11-17-2017, 12:01 PM
I believe he was but the valve's wouldn't stop the dash lever from moving, at least I don't think they would. It almost has to be the brake on or something came apart in the linkage.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-17-2017, 01:20 PM
MattC's Avatar
That's correct, the dash lever won't move. It is stuck in neutral.
Someone definitely has messed around with the brakes. So much so, in fact, that they don't work. There is no resistance when pressing the pedal. However, the lever was returning to neutral when depressing the pedal prior to the issue occurring.
I assumed it was a valve issue, because when I engaged the valve previously the hydro static would start to whine - indicating that it was working. It doesn't make any noise now, whether the valve is up or down.
I'll take a look at the linkage, and report back.
Old 11-17-2017, 01:42 PM
Look under the tractor to see if a linkage came off.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-17-2017, 02:22 PM
Terry C's Avatar
Terry C Terry C is offline
Pull the pedal towards the rear. Then move the lever while holding the pedal.Might not be returning for enough to let go of the dash handle
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 11-17-2017, 08:09 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Inside the rear fender on left side there is a round port in the sheet metal.
Looking in there you will see some of the tranny linkage. While wiggling hydro handle you might find d a need to stick a big screwdriver in there to free the worn parts that have decided to "catch".
The same worn parts are the reason for the creeping problem.
