Greg Rozar AKA- CubDieselFan
Old 10-31-2017, 02:47 PM
alsparl alsparl is offline
Default Lighter Socket Power Outlet Inquiry
I am working on a non-Cadet machine for my B-I-L as he will be using the machine for specific blade work, no mowing. The engine is a 10 hp Magnum. I am also making a new wiring harness for the machine since the old one is crumbled. With that being said, I am "considering" working in a female lighter socket power outlet for the use of charging a cell phone while he is working. If I proceed, I will be placing it in the dash panel and rework the pto switch hole (no longer needed). I assume this will work but do not know for certain thus why I am asking those whose intelligence and experience is far greater than my own. Is this feasible, not recommended, is there a specific one I need to look for (marine, waterproof, amp draw, etc)?
Thank you all for your time and consideration as it is appreciated.
Aaron
'83 782 #723927
****original KT series 1 engine
****added dual hydraulics from older, donor 782
'04 SRC621
'95 Magnum (M18S) spare engine
****spec 24646
****s/n 2507913316
Old 10-31-2017, 02:54 PM
As long as the tractor is 12v it will work just fine. Amp is limited by the plug you put into it, not by the socket. You can pick up a universal outlet at just about any parts store.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-31-2017, 03:22 PM
Perfect, thank you very much for the guidance Tim, I do appreciate it. Aaron
Aaron
'83 782 #723927
'04 SRC621
****spec 24646
****s/n 2507913316
Old 10-31-2017, 04:12 PM
Just make sure you put an in-line fuse on the positive side, if all you plan to do with it is charge a phone you shouldn't need more than a 5amp fuse.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-31-2017, 05:33 PM
Thank you Tim, you answered my question before I wrote it.
Aaron
'83 782 #723927
'04 SRC621
****spec 24646
****s/n 2507913316
Old 11-13-2017, 11:43 AM
Most phones use a 20 volt transforming charging system...I believe
Old 11-13-2017, 12:18 PM
How is that relevant?
Still 12v input at less than 5amps.....
Old 11-13-2017, 07:39 PM
Actually.... they use ~5V for charging. Usually ~1A for a phone and ~2A for something larger, like a tablet. The 5V requirement comes from the USB standard voltage. But that is produced by the transformer on the end of the charging cord, regardless of input voltage.
