Greg Rozar AKA- CubDieselFan
Old 09-25-2017, 02:21 PM
Richs72 Richs72 is offline
Default Engine rebuild ?
The engine is a Kolher 7 hp in a 72. It's using oil and blowing smoke when cold. The question is whether replacing the rings is adequate. Boring the cylinder is probably the best option but that means finding a shop to do it and the expense might not be worth it.
Any one with experience on this subject?
P.S. - this machine is also used to blow snow so I only have a short timeframe between lawn season and snow season.
Old 09-25-2017, 02:47 PM
Replacing the rings is never adequate. Find a shop and bore it. Grind the crank, get a new rod. Complete overhaul done correctly will last years. Do it "cheap" and it may not make it through the winter.
Old 09-25-2017, 02:53 PM
Is it possible to buy a new engine?
Old 09-25-2017, 04:20 PM
Dirty Steve's Avatar
YES, if you have a time a machine. Not made in a long time. Find a good machine shop and spend the money if you would like to continue on with the tractor.
Old 09-25-2017, 06:04 PM
You can purchase a rebuilt motor. I sell them, but I don't have a 7hp rebuilt and ready to go. Kustom Lawn and Garden also sells them, but they also build to order.
Old 09-27-2017, 11:34 AM
Thanks for all your advice. I found a local machine that will bore it. Any idea of the overhaul kit number that I need or how do I find out?
Old 09-27-2017, 11:57 AM
I buy my overhaul kits aftermarket from this seller:
http://stores.ebay.com/The-Mans-One-...=p4634.c0.m322
I usually just call him and place my order. You have to take the motor to a shop first and find out how much it needs bored, and what size the crank will need turned to, then order the kit. Buy the complete kit.
Old 09-28-2017, 09:01 PM
tmx43 tmx43 is offline
will these kits hold up in building a tractor pulling engine?
Old 09-28-2017, 11:04 PM
Well.... maybe. Depends on what all else you do to the engine, and how high RPM you're planning to run. If it's just a "stocker" and under 4K RPM, then by all means yes.
Old 09-29-2017, 07:07 AM
that's good to know. im rebuilding a 301 that's being bored and crank ground.
