30 degree valve
is the 30 degree valve grind worth doing in a stock pulling tractor . i got new kohler valves for a 301 but the machine shop said he had never heard or done that. he said he didn't know if the 45 valve would be right after the grind?
I won't give up angles but I would recommend a 3 angle valve job on the seats . you can nail head the valve by undercutting the head or get some stainless stock altered valves from super cub . I've been playing with cutting the valve head with 3 angles also, it gets a bit complicated considering it needs to match the seat at the middle angle
scan in the QR code (upper left) or text IHCC to 51660 to follow which shows and pulls we will be attending. |
ok im going to check out the valves at mwsc.
I think the wisdom was to change the angle on the INTAKE valve only to help with filling a bit more at lower rpm. I think that was from the flat head fords.
