CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Old 11-07-2017, 10:31 AM
charlie g charlie g is offline
Originally Posted by Mike McKown View Post
Here is some reading for you to absorb. Fuel hose is readily available that E 10 will not prematurely degrade. Same with carburetor parts.
https://www.vehicleservicepros.com/o...dern-fuel-hose
100% with you about having to know about low permeation fuel hose. what i meant was the cheap junk hose anyone can get at the local ap store. 2-3 years down the line it's junk inside.
Old 11-10-2017, 10:05 PM
David K David K is offline
If you have a shut off valve on the bottom of the tank some have screens on them the screens clog after a while. Pull shut off valve make sure valve is working and clean screen and replace. I had one that handle turned on shaft causing it not to open.
Old 11-19-2017, 07:17 AM
just had the same issue on my 08 lt1050, turned out to be a MUD wasp built a mud bridge in the tank cap vent hole. cleaned it out no more run problem
