If you dig around, one of our members cut the bad hub out of his impeller and replaced it but he had access to all the cool equipment and the ability to do it.
I have a bunch of "cool" equipment and could repair but would need the correct splined bushing to do it.
http://www.onlycubcadets.net/forum/s...=Blower+repair
http://www.onlycubcadets.net/forum/s...ad.php?t=28907 Problem with these blowers is the main gear box is NLA. Impellers can be bought or fixed.
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights. {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
You'd be surprised what else uses the same parts though. Like the augers, impeller, worm gear drive in the auger drive gearbox..... A lot of the parts inside the gearbox (bushings, shafts) can be made. The gears would be expensive, but could be gotten.
Am going to study this a bit to see if I can pull it off on my 'not as cool' equipment. We will see, stay tuned.
If you repair the old impeller, see if you can get someone to balance it. I has a buddy who runs a shop balance my impeller with the machine he uses to balance driveshafts. Much smoother. You'd be surprised really.
Just to help the search
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
Now have these things (shipping was as much as the part so I bought 2 so I can !#@$ one up. With luck I end up with a spare to pay forward to someone here.
More to come, but out of town for a bit before I can get back to it. |
Those are the correct splined couplers. Just some advise. When you go to turn down the OD on a lathe to press into the blower fan, make sure to chuck it up so the ID of the splined coupler runs true in the lathe. The OD and ID of the couplers I've seen are not true to each other.
1450 w/ 44gt deck, 1572 w/ 50C deck, 450 snowblower. |
Finally got to re-splining this. Too large to swing on my lathe so had to bore it, some light cuts made do.
Think I had the wrong belt on it, and also no #15 as sbauerz points out. Will pay attention putting it back together to be sure its fully engaged and lined up. Pics before welding. |
Thread Tools | |
Display Modes | |
