Greg Rozar AKA- CubDieselFan
Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Briggs & Stratton Engines
Old 09-25-2016, 07:24 PM
joem789 joem789 is offline
Default 1440 14HP V Twin engine HOT!
Hi
My CC runs great and all. But it seems like after I mow for awhile it tends to overheat and not want to run at all. It'll sputter, then die. And then just plain will not fire up. The starter whirls over But no kick. After a few minutes, it might start up and then immediately die and stay dead for maybe 30 minutes or when it cools down. I haven't been able to pinpoint what causes this. Is this a common issue with V Twin engines? This engine is built quite a bit different than the standard B&S lawn mower OHV engines I have dealt with in the past.
Thanks
Joe M
Old 09-25-2016, 07:34 PM
You engine is likely vapor locking. Do you have the heat shield in place behind the engine?
When the engine stalls, remove the gas cap and pressurize the fuel tank for about 30 seconds and see if the tractor will start back up right away.
I have to run my Kohler Command and Vanguards with the side panel removed on the fuel pump side to prevent this. I also do not have the heat shields behind the engine installed and I believe this contributes to exhaust heat recirculating around the fuel pump.
Old 09-25-2016, 07:51 PM
You may also have a bunch of crud in the cooling fins. Time to pull the engine, remove the tins and give it a good cleaning.
Old 09-26-2016, 09:10 AM
Thanks y'all. I'll be mowing today. Will see it goes.
Old 09-26-2016, 10:41 AM
At least check to see if you have good air flow out of the front of the engine near the exhaust pipes. You should feel a pretty good breeze, if not you have plugged up fins and continuing to run it will damage the engine. Mice love to build nest's in these things and then they over heat.
Old 09-26-2016, 10:53 AM
Tom4981's Avatar
Tom4981 Tom4981 is offline
Not to hyjack the thread but I did that a couple of weeks ago, couldn't believe the crud that accumulated between the fins.
Old 09-26-2016, 11:14 AM
Here's another example. Leaky crank seal PLUS a mouse nest.
Old 09-26-2016, 02:15 PM
Dirty Steve's Avatar
Been there,done that. Clean it out now and save your self some serious cash.
http://www.onlycubcadets.net/forum/s...ad.php?t=43441
Old 09-26-2016, 02:38 PM
Steve, check your PM's.
Old 09-26-2016, 02:45 PM
That was pretty helpful. Looking at the shroud (grill?) there was quite a bit of grass blocking the holes. Nearly all of them. I took it off and dug it all out with a brush inside and out. I poked around the fins best I could to see if there might be a nest up in there. But it seems to not be. The exhaust in the front blows out strong. So I am guessing so far the grill was just getting blocked. I bame myself for not taking the time to check such things. Let's hope this is the problem! The rain came in suddenly so I didn't get a chance to find out. Maybe tomorrow.
