Greg Rozar AKA- CubDieselFan
Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Kubota Engines
Old 11-24-2011, 10:43 PM
emptypockets95's Avatar
emptypockets95 emptypockets95 is offline
I use 15w40 rotella and a little bit of Lucas in my 1572. I also suggest the kubota filter or a fleetguard filter. Also to lubriacte the top end of the cylinders and injector and injector pump use lucas fuel treatment int he winter and 2 cycle oil on summer in your fuel.
Justin
Old 01-17-2012, 06:33 PM
Rotella 15W40 is good stuff. Used to get 20,000 hrs on my Cats with it before overhaul and the bearings were still in spec. I use it in my Kubota BX as well as my gas engines. As far as filters I like NAPA gold or Wix filters. Just my 2 cents.
Old 09-08-2017, 09:27 PM
bsm2003
Guest
Posts: n/a
I use Rotella T 15w-40 in everything. Makes not having to keep 3 or 4 different weights of oils around. It doesn't hurt gas engines at all. Even my 444 Case calls for 15w-40 in the hydraulic system.
Old 09-08-2017, 10:18 PM
That all depends on what engine it is. Newer motors have very tight tolerances, and if you run that heavy of oil in them you can damage the bearings. The oil is too thick and just opens the bypass valve in the oil pump. Oil starves the bearings.
Oh.... and this thread is from 5 years ago.....
Old 09-08-2017, 10:25 PM
Green stripe wide frame's Avatar
Green stripe wide frame Green stripe wide frame is offline
Originally Posted by superduty5.9 View Post
I too would only use 15w40 Rotella T. Btw when you say Detroits you must be refering to the 2 stroke Detroits. We use SAE 40 in our 2 strokes. If it's a Series 60 or even a Series 50 we still use Rotella 15w40.
102 soon to be tiller machine
108 mower
73 plow machine
169 soon to be mower
122x2 now parts machines
Parts 129
149 parts
61 "O"
104 job to be determined
Old 09-23-2017, 03:58 PM
jah457's Avatar
jah457 jah457 is offline
I use Rotella T 15W-40 and Wix filters part #
Air - 46270
Pre fuel - 33972
Fuel - 33389
Oil - 51064
Hydro - 51410
Much appreciated
