Greg Rozar AKA- CubDieselFan
Old 10-29-2012, 03:54 PM
AdamInKC AdamInKC is offline
Default LTX1040 - Issue with parking brake. Please help!
I was mowing up leaves last weekend and when I went to release the parking brake the lever would not release. The only way I could get it unlocked was to open the engine lid and pull up on the lever that has the locking mechanism. I verified the rod that connects the park brake lever was attached and connected to the locking mechanism; however it is not releasing the brake for some reason. It appears that it is not pulling it up enough. Whenever I fully depress the brake pedal, it automatically locks down now. It should only lock down when I depress the brake and push the parking brake lever down.
Any ideas on what could be causing this on my 2009 LTX?
Old 10-30-2012, 04:23 PM
Vince_o Vince_o is offline
Theres a bushing, plastic that wears some times on the brake shaft, also a cotter pin way up in there that if it catches right will do what your describing. Ive only seen that twice with the pin.
Old 11-01-2012, 04:01 PM
Default Fixed!
This was tricky to find... way up in the hidden area where the parking brake rod attached to the locking mechanism, there was a piece of think mulch that had wedged under the locking arm. This caused the arm to not be able to slide back far enough and the brake would lock every time it was depressed.
Thought I'd post up the fix in case anyone runs into this in the future.
Old 11-04-2017, 09:47 AM
Ray&Paula Ray&Paula is offline
I know this is an older post but, thanks for the info...... Right now I can't engage my parking brake on my LTX1046......... Created a thread today looking for some idea's/help. Glad to see you got yours fixed. Ray
