Choosing a tiller
hi guys i have a question to ask i am having a hard time choosing between buy a ih cub cadet tiller for my 122 or buying a dr power tow behind tiller i will be making lavender rows in hard clay and tough prairie grass which way would you guys go and why
thanks thad |
I have a 1A tiller ( one extension ) and it cuts gardens into turf without a problem using my 125. It does take two or three passes to get to full depth but works well.
I have 4 seasons ( total of 15 gardens ) using NAPA belts. |
Depending on the size of your lavender patch I would go with a walk behind tiller like a Troy-Built tiller. I own a #2 tiller on a IH Cub Cadet 128 and a Troy-Built horse tiller. I have better control of the Troy-Built tiller than my rear mount IH tiller.
My soil is hard pack clay soil. It may take a little longer with the Troy-Built....The Troy-Built does a better job all around than the Cub Cadet tiller. If you are set on a tiller for your 122 I would go with a IH Cub Cadet tiller. Tillers are good at pushing your tractor. The DR one looks like it hitches up pull behind type implement does. The tiller could jackknife your rig real quick if you aren't careful.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
i have a walk behind tiller already just hard to control and takes to much time also i will be runing a subsoiler through first to about 1 foot deep before i run the tiller throught
I've used IH rear mounted tillers and a walk behind. I'd rather sit and drive so I chose the rear mounted tiller. I also would say an IH tiller because you are using the tractors engine and not another external one like with a tow behind.
Daniel G. . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
