Snowthrower differences
Hi:
I purchased a snow thrower that fits my 149 and was wondering what the differences in a qa36 and a qa42. It doesn't have any numbers on it. thanks, Clay |
the 36 is 36" wide and the 42 is 42" wide.
If I'm not mistaken a QA-36 OR a QA-42 neither one will fit your 149.
You need a QA-36A or a QA-42A.
Yosemite Sam is right. Have you tried to mount it yet? The A at the end means adjustable. There should be different holes to make it fit a wide frame or narrow frame.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
As a qa42 or qa36? |
And NO. A QA36/42 will not fit a 149. It has to have the "A" at the end. |
I put a QA36 on a 129, it left a bit to be desired. I had to cut and widen the mount. Then when I got it on, It couldn't be raised up all the way or the chute would get into the hood. That's when I realized the grills on that series angled toward the front while the older Cadets angled toward the operator--hence the clearance problem. We left it on all winter, never got any snow so I sold it. Now we have a 122 and 124 Cadet
In relationship to snow throwers, 36 or 42 is the width (in inches) of the path the thrower cuts.
Post up some pictures of what you have there.
These are my photos.
