Any hope for my deck?
I have a 127 with a 48 inch deck that has been just fine till today. When I put the pto in gear, I could hear a grinding noise. After some looking, I narrowed it down to a spindle. The spindle is still tight and it doesn't wiggle like the bearings are bad when I grabbed the blade from below. However, the pulley is loose on the shaft. I tried to shim it up with some washers but the key stock keeps it from engaging the pulley. After taking the belt off, the pulley wobbles about 1/8 side to side. So my question is, do I need to replace the pulley or is it an easy fix that I'm not seeing? Any help is much appreciated.
Where's the nut??
I took it off to get a better picture of how loose it is on the shaft.
Well... the way I see it, you have two choices.
1.) Replace the pulley and the spindle 2.) Put the nut back on and tighten the crap out of it. |
From what I see you can't hurt it any worse! Got a pair of calipers? If so measure the shaft and the pulley so you know for real how bad it is. Maybe consider a new key. If the shaft and the pulley are both worn just a little, maybe you could make a shim from a soda can and wrap as much of the shaft as you can--obviously you can't wrap it all the way due to the key. It's not a repair, but a band aid if you need to get running quickly and cheaply.
One set screw to push and hold the key way, the other 1/4 dia. away. The pulley's are pretty inexpensive just bought 2 for my deck but don't recall the price. The spindle can be pricey unless you can find a good used one, I found one on E-bay a while back that was reasonable, because the used deck I have was missing one. Keep us posted. |
All good answers that I cannot add anything too.
If I may,I will mention, as late as it is in the season, the suggestions given will prolly get you through it. keep yer eyes open on ebay or post a "wanted"ad here for what you need. |
Thread Tools | |
Display Modes | |
