Hydraulic blade for a Cub Cadet
I have a chance to pick up a hydraulic blade for my 1450. Were they originally made with connections for these kind of attachments or was that a separate option? If they can be attached stock wise, where about would the lines hook up? I have never looked before, just figured this would be the easy way out.
cub14501650, the hydraulic 'power angle' plow is made to be used on a tractor with 'dual hydraulics'. Dual hydraulic or 'twin stick' tractors have quick connect couplers on the front of the tractor. They also have two levers, one to control the lift and one to control the angle.
Like this; http://www.onlycubcadets.net/forum/s...301#post347301 |
Dual hydraulics were an option. You could add them, but it is kind of costly. I wouldn't add it to a 1450 just because of the work involved.
No simple solution for you other than to say the blade is useless until you have a tractor to put it on. |
Thanks for your help guys. It's in nice shape, not a nice price, but I may buy it just to keep it until my estate sale.
The blade will work just fine on your tractor. You just won't be using the hydraulic function. You will have to add a stop to the blade to hold it at whatever angle works for your application.
Or he could just remove the cylinder and put a pin back in the original location. That would be easier than adding what it already has, wouldn't it?
Yep, then he could sell me the hydraulic angle kit
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
