Greg Rozar AKA- CubDieselFan
Old 11-17-2017, 01:03 PM
Userj8670's Avatar
Default Elec PTO on 1x8/9 series
Any one ever put an elec pto on in place of a manual?
Old 11-17-2017, 01:09 PM
It can be done but only if the the block has the threaded holes to bolt the PTO on.
Old 11-17-2017, 01:18 PM
Lanceskene's Avatar
Lanceskene Lanceskene is offline
There is also at least two differant bolt patterns that Im aware of. K341 is bigger maybe???
Lance / Alberta Can
IH 127 w/deck, snowblade
IH 154 Loboy(x2) w/creeper 3pt and 3160 deck
CCC 12.5 w/deck
Plus 35 or so non IH tractors
Old 11-17-2017, 01:39 PM
Userj8670's Avatar
Well I have a 169 - I assume then I'd have to drill the block?
Old 11-17-2017, 01:41 PM
If it's the original engine then you would need to drill and tap the holes, if it's been replaced it's probably already tapped. What's wrong with the mechanical PTO?
Old 11-17-2017, 05:39 PM
Userj8670's Avatar
Nothing is wrong with it. But let me give you an idea where my heads at. I am confident your familiar with the 364 blower which (with a 418 kit) attaches to a quietline. I have a 418 kit off a 1650 and wanted to see how it fit on the 169. It fits well but the idler pulley on the kit hits the arm for the engage/disengage. Thus if I had an elec PTO I could remove said hardware and theoretically be good to go.
This is all brainstorming at this point **
Old 11-17-2017, 05:57 PM
ironman's Avatar
ironman ironman is online now
I'd be assuming your 169 starts with a starter generator (maybe not), but if you drilled and tapped and replaced the manual pto for electric, how would you start your engine or charge your battery??
Old 11-17-2017, 06:21 PM
Good point, I didn't even think of that when I responded earlier.
Old 11-17-2017, 09:26 PM
sawdustdad's Avatar
Easy solution. Just buy a QL cub cadet.
Old 11-21-2017, 02:56 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
Probably the easiest, and most cost effective option.
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
