Cub Cadet 107 hydro lever moves going uphill
I recently had the hydro pump out of a 107 to replace seals, gaskets and to fix the trunnion square (installed new springs) but am noticing that when going uphill i notice the speed control lever on dash moves itself to the neutral position which ends up stopping tractor in its tracks. If i hold the lever in a stationary position when going uphill it has no problems, noises or lack of power and keeps a constant speed. Is this normal movement to happen when going up hill. I know the speed lever isn't a cruise control but not sure if the rapid self speed decrease is normal. This is my first hyrdo tractor so looking for advice if there is an adjustment or something that needs done. When driving around normal flat ish ground the speed lever does hold its position.
It should be above item #20 on the attached image. It compresses item #22, the Friction Discs.
Ok thank you!
