#21
I got to try out my subsoiler yesterday. It works great. It would work even better if the 100 could get enough traction to pull it better. With 130 lbs of weights and chains it still wanted to spin a lot. There were a lot of tree roots so that didn't make it any easier. A couple times it caught a root and when I went to raise it a little to stop the tires from spinning, it ended up lifting the front tires about 8" off the ground. I managed to get it worked up about 10" deep. Then I put the disc on and leveled it out.
I may try adding some weight to the subsoiler to get it to sink better. I tried it with the 3-point on float but it wasn't heavy enough to sink into the ground. It just wanted to scrape along the surface. I had to use down pressure to get it in the ground. That didn't help the traction issues since it was taking weight off the rear tires.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
#22
I did get some pics with my phone. I'll see if I can figure out how to upload them to my computer.
#23
Wow! That sounds like you had a lot of fun yesterday! It takes a lot of power to lift the front end 8 inches- thats a lot of weight.
#24
send the pics to your computer email then go from there.
#25
Adam's pictures:
-105___ Tiller |
#26
Thanks Conner!
#27
Great Work!
#28
Looks good! Great looking dirt too!
#29
Wow that looks like fun!!!
Dale 147-Restored___________________882 Diesel Hydro lift (not installed)___________44" Deck 48" Deck_______________________QA-42a/b Snowthrower Rear lift ________________________XMW cat-0 rear lift Model 2 tiller____________________12" cat-0 Brinly plow |
#30
Better picture:
-105___ Tiller |
Thread Tools | |
Display Modes | |
