Greg Rozar AKA- CubDieselFan
Old 01-25-2018, 12:45 PM
Merk Merk is offline
What is the engine going to be used on.. puller or daily driver?
Puller- head strap it and send it down the track.
Daily user-you might consider installing a sleeve and make the bore back to a stock 12 horse bore.
Project Uncle Dick
Cub Cadet 70
Old 01-25-2018, 04:33 PM
I would think,
If the cyl is too thin @ the block intersection area, sleeving is not going to keep it from breaking off the block.
Old 01-25-2018, 05:46 PM
I would think,
I have two K321 blocks that been sleeved. One is in a puller. Have had any problems. The daily user was done 7-8 years ago. Adding a sleeve may work. The only possible issue is the sleeve isn't big enough(outside diameter of the sleeve)-bore too big.
Project Uncle Dick
Cub Cadet 70
Old 01-25-2018, 06:10 PM
Dale, do you recall the OD of the sleeve?
Old 01-25-2018, 06:36 PM
Local machine shop takes care of installing sleeve and all machine work. Not sure on OD.
Project Uncle Dick
Cub Cadet 70
Old 01-26-2018, 12:45 PM
austin8214's Avatar
Well apon further inspection of the block. Measuring the OD of the bore between the fins I get 3.8xx so I'm going to head strap it for insurance purposes although it probably isn't needed.
