Greg Rozar AKA- CubDieselFan
Old 12-23-2017, 07:41 PM
tlcan tlcan is offline
Question AS vs AQS
What are the differences between a K series AS engine and a K series AQS engine (internal or external)?
Old 12-23-2017, 09:10 PM
As found on page 1.3 of the Kohler Service Manual.....
Roland Bedell
Buy: Made in the USA
Old 12-24-2017, 12:04 AM
Your question is kind of ambiguous, so I'll give a simple answer:
Not much. Do note that if you are looking for a replacement engine, you can use an AQS engine in place of an AS, but not the other way around. The AQS engines do have holes drilled in places that the old motors don't, and are sometimes missing the hole for the dipstick on the front right corner of the block (as installed in the tractor). That hole can be drilled though. Freeze plugs can be installed in the other optional holes that are there for the later style dipstick. All parts between the two styles are interchangeable. Just look out that you have all the provisions you need.
As a note, the later style Magnum K series do not have the spot to mount points. If you are good at machining, you could likely machine/drill them, but they don't exist stock.
