Another primer question
Do any of you or has anyone ever used hardner in their primer? Read online somewhere where they were talking about using hardner in with their primer. I was curious. thanks brian
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! |
on one type of primer you do, can't remember if it's 1k or 2k... it should say on your primer can what or if you mix it. One of them gets thinned out, and the other gets hardener added. that's speaking of automotive type primer.
Gary '49 Farmall Cub, '62 "Original, '70 73 w/402-D Haban sickle, '71 127 w/38" cast end deck, '73 149, '76 Sof76, '07 LT1045 w/bagger, '09 GT2544 w/bunch of mods. 5 Exmarks, Kubota B2920, blah, blah, blah... |
Interesting, considering what hardener does, I never thought of adding it to primer.
Hardener has always made my paint shine more, would that possibly be a negative effect!!?? The next coat might not "bond" as well to a high shine surface. I love how hard the paint gets with hardener, this tractor would have looked like without it!! That is a 4 year old paint job!! With non-automotive, equipment paint. |
My primer doesn't say use hardner,just thinner. I had never heard of using hardner with primer either. I thought the same as CADplans it would have the affect of the top coat not adhering to the primer like it should. Thanks guys for the fast response!..Brian
Some auto paint systems use primer with hardener. PPG 'Shop Line' is one that does this. If it doesn't say to use hardener with the primer, I wouldn't.
I use epoxy primer and it is a 2 part system, primer and activator(hardener). It creates a chemical bond to the metal and also creates a very durable sub coat for paint. I use PPG omni products.
Kubota B7100 HST 4x4 w/FEL, 4' Bush Hog, Woods RM400 Finish Mower Original Member #54 |
Here's what I use.
all 2k primers take a hardener. they are a high build primer. the kind you mix a reduser with is just a etching primer/ low build. aka (junk primer) my 0.02
you can use reduser in 2k primers and make a sealer out of it before you paint.
Doug Original / IH 70 / IH 149 / IH 1650 / IH 582 / CCC 1772 West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
Thread Tools | |
Display Modes | |
