Greg Rozar AKA- CubDieselFan
Old 12-30-2011, 10:56 PM
Those spindles might be annealed by welding and loose strength.
(A bent spindle is worse than a sloppy spindle)
Could you put a sleeve over it and find a larger bearing??
Old 12-31-2011, 09:04 AM
They had stuff welded to them at the factory, so I wouldn't worry about that.
Old 01-02-2012, 09:07 AM
jim102 jim102 is offline
im not worried about mig welding a few ribbons. like i mentioned im going over entire tractor as a resto so it really wont be doing any real work afterwards, more of just hauling kiddie cart around.
Old 03-05-2012, 11:54 PM
C5rider C5rider is offline
what about turning down the spindles to 3/4"? That's the size of the other CCs and, bearings are readily available. I'm pretty sure that you could get the size to match your wheel, right?
I'm contemplating this right now as my Original needs some attention here.
Just started a new thread cuz I didn't see this one originally (no pun intended).
I went ahead and taking Happyhab's idea, I simply drilled out the original bushings to a 1" ID and used bronze bushings from ACE hardware. They cost about 8 bucks a side and they're tight for now. We'll see how they hold up. Drilling out the original bushings trued them back up again and, gave me a spacer to go between the new bushings and the wheel. I believe they are more of a steel consistency than the bronze bushings as when I drilled them out, the material looked much different. I think the bronze ones that I installed are softer and since they're easier to find, I can get them at the local hardware store. Hope this helps.
