center mount grader blade
I bought a center mount grader blade from a guy who said he had it mounted on a 125 and found it while cleaning out his garage. My question is, does anyone have any info on the center mount grader blades? It doesn't have any names or decals on it.
I'm sure someone will have info....maybe contact Myron Bounds. He has tons of info. He is a member here and a sponsor!!! Even if there isn't any identifying info ID, imagine there aren't to many that were manufactured for our cubs!!
Any chance on uploading some pictures? I have two brackets for my 70 that were mounted to the rear end that the only thing I could figure they were for was a center mount blade. I'll post some pictures later for you, have to leave now!! At any cost I'd say your a lucky man!!!The center mount blades are a bit rare I'd imagine! Good luck Jason
Jason Davis :biggrin2.gif: Just one more !! |
I have absolutely no idea if these would be used for a center mount, they are heavy duty!! 1/4 plate. I posted pics on all the cub forums and the best/only suggestion was for a center mount belly blade!! They just sit in the corner now!! Take care,Jason
By the way,WELCOME !!!!
Got a double one one of the pictures Sorry,wont let me edit right now!!
Here are the pics of the belly blade
Here are the pics of my belly blade, has anyone seen anything like it? How is it mounted?
Thanks Rod |
That looks like the front of it mounts to the mule drive for the deck, with the rest of the deck carriage removed.
That blade mounts on the front where the mule drive mounts .
I saw one at a show that it mounted in front. They had the mule drive off. that looks like the one I saw. I didn't craw under to look at it because it was too wet. The ground was wet not the tractor. ole 147 |
I have one just like that one that I was trying to figure on useing,
but could never figure out how to mount it I thought I was going to have to mount it on the rear like a back blade, didn't have the pins at the front of the carriage. It's a heavy blade and thick dang thing weighs about 30 or 40#'s it's just like the one you have, painted red and no name or decals |
Just wondering would this work better if we would mount or hitch
the pins to the u-bracket below the hitch on the back of the tractor and push the blade instead of pulling it ?? |
You could, but the structure would have to be heavier because now you're trying to buckle the framework of the blade pushing on it instead of putting it in tension by pulling on it. There's actually a better reason, but I can't remember what it is...I was talked out of mounting it from the back when I made mine.
Thread Tools | |
Display Modes | |
