Greg Rozar AKA- CubDieselFan
Old 11-17-2016, 09:55 AM
Baccarat Baccarat is offline
Default Painting the miscellaneous
I am going to have a local strip & paint company doing the stripping & painting of the frame, mower deck & a few of the larger items off of a Cadet 95. They will spray the color based on the Paint Chart information that I have found here which is a 935 white.
I plan on rattle can painting the miscellaneous bolts, nuts, etc. Is there a way to cross reference the correct spray can number to the quart can number? I noticed on the paint chart that with the exception of IH & CC, none of the other paint sources show any spray can options.
Mike
Old 11-17-2016, 02:56 PM
You will have a difficult time matching a traditional paint color to a rattle can. I would try to prep all your other items first and let them paint them all at once. Sometimes you can go back to where they mixed your paint the first time and it won't match to next time you buy it. I try to buy enough paint to make sure I can paint the whole tractor and have some left over for any mistakes.
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 11-17-2016, 07:57 PM
john hall's Avatar
Some paint suppliers can mix paint and put it into rattle cans. The local Sherwin Williams can't but one about 45 min. away can--we have it done so we have touch-up paint available to match one of our customers equipment in their plant. Maybe you could get a couple spray cans mixed at the same time you get your regular paint mixed.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 11-17-2016, 08:44 PM
I would just buy new nuts & bolts, there cheap and you don't have to worry about chipping the paint off them when your putting it together. It also makes it easier if you need to work on it in the future.
Old 11-17-2016, 11:14 PM
Terry C's Avatar
Terry C Terry C is offline
X2! That's twice in one day we agree, bad sign.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 11-17-2016, 11:34 PM
OldSkull's Avatar
OldSkull OldSkull is offline
X3 What he said! That's what I do and new nickel plating bolt look good!
Someone as referred Dupli color School bus yellow ($7) to be a pretty good match, I try it on small parts, nuts and bolts and I like the result! No more expensive Cub Cadet yellow spray paint can for me!
Gilles.
1963 100 (red)/in storage
Old 11-17-2016, 11:46 PM
Yeah that's fine unless he's going for the original painted bolt look, then he still has to have the hardware painted...
Old 11-18-2016, 09:12 AM
You should just accept the fact that I'm always right and agree with whatever I say.
Old 11-18-2016, 09:14 AM
Then he should do what they did at the factory and paint the tractor while it's assembled.
Old 11-18-2016, 11:50 AM
There are a lot of good ideas here.
I'm not sure that I would be a fan of painting the whole tractor assembled as they did in the factory. Things that should not be painted at all seem to get painted. I.E. the steering links, springs, etc. Things that should be painted don't get full coverage.
My first instinct was to simply replace the nuts, bolts and washers unpainted. I'm not sure that I like the looks of that, but won't dismiss it either. I did plan on replacing all of the mounting hardware anyway.
I thought of testing spray cans and finding a color that is as close as possible to the frame & mower deck. That might take a hit and miss approach, hoping to find one that is close enough. Having the paint manufacturer custom supply a few spray cans is one option that I didn't know could be done and is something that I will check into.
One other thought that I had was to get a hobbyist "air brush" and use the actual paint supplied. Has anyone tried that? It would or could give me the absolute color match. Also, I could assemble some of the work and then "touch up" the bolt heads and nuts as I proceed further along. I am not sure that it is a workable solution, but seems to be a possibility. Any thoughts on this course of action?
