Greg Rozar AKA- CubDieselFan
Old 11-28-2017, 07:31 PM
john hall's Avatar
Default KT/Magnum fuel pump
Need a new fuel pump for my 782 spray tractor. Price on these things are all over the place--and that's for aftermarket. I bought one from an Ebay seller last spring (The Mans Shop--or something like that). Its in the $50 range. Ran it all summer on the M18 in the 1811 with no problems. Lots of sellers on ebay with what appears to be the same pump kit starting around $20. Only difference I see is some have brown O-rings, others have grey. According to the seller I bought from last spring, he gets the pumps from the same factory as Kohler. What have you guys been buying lately? I hate to be so cheap, but I just dropped a small fortune on 2284 parts last night.
Whats your thoughts gang?
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 11-28-2017, 07:36 PM
As with most everything,.... the cheap ones don't last long.
Old 11-28-2017, 09:37 PM
Vrobert's Avatar
Vrobert Vrobert is offline
I bought a cheap one for my M18 without knowing any better. It came with several fittings of different sizes and angles. It installed easily and doesn't leak but I only have 30 minutes of run time so far.
Prime Line 7-08016 Fuel Pump from eBay for $28.00
Rusty 149 project with:
QA42 snow thrower
38" deck
Barn fresh 1811 with:
44c mowing deck
QA42A snow thrower
42" snow blade
Old 11-28-2017, 09:51 PM
I've bought a few of the cheap ones and haven't had an issue yet.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-28-2017, 10:23 PM
As a note, I will say, I have installed the Prime Line fuel pump on customer machines before. As far as I know, no issues. I know I used to use Stens, and I didn't have good luck with them. On my 1811, I've only had to replace the pump one time. Put a Kohler one on it......13 or so years and around 800 hours ago. Still working fine. I'm not opposed to aftermarket stuff. Just haven't had very good luck with fuel pumps in the past. Lots more choices now than there was a few years ago though.
Old 11-29-2017, 08:12 PM
OldSkull's Avatar
OldSkull OldSkull is offline
You got many machine to take care of John, if this is not a everyday horse I say "Roll the dices" and go with the aftermarket one. I got 2 Magnum with aftermarket one and so far they start and purr like a kitten.
Gilles.
1963 100 (red)/in storage
Old 11-29-2017, 08:20 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
I agree if it fails prematurely...chalk it up to another learning experience!
Queen Of The Quietlines!
Old 11-29-2017, 11:12 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
I've had good luck with the Prime Line pump.. But I only run 100 percent gasoline.. no ethanol or even 10 percent ethanol for me.. we tried that for a few years.. everything we had with a carburetor gave issues.. swapped back to the non ethanol fuel and no problems since..
Jay
Proud owner of the following:
