Greg Rozar AKA- CubDieselFan
Old 10-16-2017, 02:07 PM
dbuck dbuck is offline
Smile Sv720
Starts on full choke and 1/2 throttle. Let it warm up a tad and go to open choke it will sputter an die. If you keep the choke at 3/4 it will run fine. Cleaned the fuel tank, new fuel hose from the tank to the filter (new), new fuel hose from filter to fuel pump, also new hose from pump to the carb. fuel showing in the filter. Also been thru the carb. If anyone has any ideas/suggestions on this problem, it will greatly appreciated. Thank you for your time.
Don B, USAF 1962-1968, Ft. Wayne, IN
Old 10-16-2017, 02:48 PM
I think you have "missed a spot" in your fuel system cleaning.
Old 10-16-2017, 03:34 PM
Clean and rebuild the CARB....
Roland Bedell
Buy: Made in the USA
Old 10-17-2017, 10:29 AM
mickb72 mickb72 is offline
Something down in the carb. Could be those pesky little o rings on the slow jet have degraded. These things are jetted lean, so they like a touch of choke. Check your choke adj to make sure it's doing what you think it is. Mike
Old 10-17-2017, 12:12 PM
Smile
Thank you Guys for the replies. 35-853-05-S carb kit NLA, use 32-853-11-S complete carb @300$. I will go thru the fuel system again and clean the carb again. If anyone has a line on were I might come up with the carb kit, I would appreciate it.
Old 10-18-2017, 09:33 AM
Lakota Racing should have parts. Carrollton, Ohio
Old 10-20-2017, 10:55 AM
Smile
I will check them out.
Old 11-23-2017, 03:48 PM
charlie g charlie g is offline
http://www.cubcadet.com/equipment/cu...kh-24-757-18-s
Cub Cadet KH-24-757-18-S
Kit, overhaul w/gaskets (SV720)
More details
Your price: $50.59
thats right from cub cadet for a sv720-0010 from a 2008 they don't give it a item number to click on just drag down the list to the very bottom
http://www.cubcadet.com/equipment/AR...D/6900578I0015
