Greg Rozar AKA- CubDieselFan
Old 06-29-2015, 12:59 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Default 1864 Resto-Fication
After many threats, the 1864 is finally getting re done. Nightow1 got the basics torn down and cleaned with my Hotsy. To start, we are going to pull the axle tubes and drill the drain holes and replace the seals and gaskets.
I have been buying parts for the last couple years in anticipation of this. Tonight i purchased the 3point plate from xmw. Kinda excited!
Got a decent little list started.... should be interesting
Old 06-29-2015, 02:27 AM
I can't wait!!!!
Old 06-29-2015, 06:07 AM
Grampie Grampie is offline
Ditto!!!!
Old 07-01-2015, 01:51 AM
Rescue11's Avatar
Welp i just spent some more money...
I ordered the paint, new hydro springs, spacers, and rear end gaskets from r.f. houtz.
At this point i need to get the frame prepped for paint, do the rear end drain mod, install new gaskets in the rear end, and replace the hydro springs. Once the paint shows up i can begin painting the frame and rear end.
Once this part is completed i get to start on the threepoint and hydraulics!
I did measure the 3pt arms on my 982 and found they are only 2" longer than the gt ones. I don't like how the gt arms can rub on the tires if they are set in the lowest forward most hole. (Keeping the very end of the arms closesed to the tractor as possible) Dont like stabilizer chaines either. SO my plan is to build duplicate sgt arms that are shorter in length, then build the sway blocks that mount to the actual plate.
This will keep the arms close to the plate, away from the tires while allowing me to have the 20" spread that is the industry standard!
No pix but hopefully soon
Old 07-01-2015, 05:10 AM
Do you have any plans of putting hydraulic front ports on your tractor while it apart? They're pretty nice to have just in case you ever need them. Being as your spending more $$$$$$!!! Sorry! lol
Looks like your going to have yourself a real workhorse of a machine when your finished with this project.
Old 07-01-2015, 09:07 AM
Rescue11's Avatar
Yes sir! One set on the front and two sets on the back. Will have 3 valves on the dash. Havent yet decided about putting a fourth in... would be a tight fit!
Plan to build a hydraulic top link like the new magnums come out with, then build a quick-tach.
Getting ahead of myself lol it should b fun
Old 07-03-2015, 01:26 AM
Rescue11's Avatar
Well my order from xmw arrived today... not gunna lie, i was excited! Waiting on my other order to show up from another place that lost my list...
Anyway, im kinda at a stand still until the paint shows up, but it gives me more time to think about other things i might do to it. I have been looking for a hydraulic cylinder for the rear end.
Old 07-20-2015, 09:57 PM
Rescue11's Avatar
Keith and I now have the rear end cleaned, drain holes drilled, new gaskets and seals installed, new filter installed, new hydro springs and spacers installed, and a fresh coat of black paint on it
Keith painted the gt axle braces and installed them.
I re c ieved my rf houtz order last week, included is the paint. Going to do a little research on prepping the frame for paint so we can get to my favorite part... hydraulics
Heres pix of the rear end during the drain mod. It was very clean when we pulled it apart!
--Anyone kno where to get a new or reproduction wiring harness for an 1864?
Old 07-21-2015, 07:23 AM
You guys are having way too much fun. Nice work on the axle drains.
Old 06-06-2016, 10:40 PM
Rescue11's Avatar
Finally starting work on this thing again. Got a guy that has it in his shop prepping it for paint. Hopefully the yellow stuff will be out from paint n a few weeks or so.
Still have to visit O'Reillys to get my paint matched for the plastic.
Took a few pix of decals Maple Hunter doesnt have for the 1864, so hopefully they turn out good enough that they can recreate them to offer the public.
I plan to start building my Unlimited cat 0 3pt after the frame is assembled on the rear end.
1- 1200 in pieces
1- 1864 in pieces
