Blade subframe mount
Hey all!
Pretty new to the Cub Cadet world, but I needed a mower, and my dad had bought a 125 a few years back that wasn't being used, so I hauled it home. And also picked up a 127. I can be a bit obsessive I guess. This probably isn't the best hobby for me. Anyway, I ran across a blade that I couldn't pass up, and was told it was for a narrow frame (and it sort of looked like it from what I can tell, based on the QA pins). When I got it home, I couldn't get it to bolt on to the 125. So I started measuring. Can anyone tell me what I've got here? I THINK it's a homemade wide frame modification, but I haven't seen anything quite like this around. The ~28" measurement is from the front of where the shaft would slide over the implement lift cross bar thing, if anyone is wondering. It looks to be ~3" short of fitting into the QA slot, and ~2" wider than the front of my frame. If it is that, am I better off trying to find a new subframe, selling this and trying to find a narrow frame, modifying this to fit a narrow frame, or buying a wide frame cub? Thanks for the help! |
Here's some measurement off the front blade I use on my 125
Welcome to OCC |
There is something with the Sub Frame. That is NOT typical of a NF sub frame. That offset is strange.
To quote Buzz Lightyear.
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
I think my mule drive on my 682 might have that funky bend.
Randy
2 original cub cadets 1 100's 2 149's 1 73 1 2182 |
IMO someone took a N/f QA subframe and modified the one side, for some unknown reason. (some sort of PO added lift cylinder? dunno.) Normally the sub frame ends that attach to the rock shaft are the same on both sides (see Jeff in PAs post) and it mounts on the outside of the A brackets that hold on the rock shaft outside the tractor frame.
Daniel G. . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
Thanks for the feedback guys. If they modified it, they also made it longer from the rock shaft attachment part to the front QA pins.
I dunno. I'd hack it back into the "normal" subframe if it's no great loss, but if it's a direct fit for a wide frame, I might be money (and time) ahead just passing this on and picking up a functional narrow frame one. |
Here is a pic I just took of the blade on my 108, WF I think. One minor modification I think that I am going to make on mine, is lengthening the tops of the tips of the frame, so that you are not trying to line up four thing simultaneously. I want to be able to get the tips sitting up on the back support bar under the frame, and then line up and slide on the front support. Having to do this solo and mostly one armed, it just isn't fun....
John
John H. Running a 72/73 Cub 108 |
A block under the front of the subframe does wonders.
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
Thread Tools | |
Display Modes | |
