Greg Rozar AKA- CubDieselFan
Old 06-19-2018, 10:26 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
okay I can't resist asking.............
I always thought the R1 or 2 or 3, etc. was the revision level of the part.
Is that not true ?
If true that bearing has been revised 91 times?
Old 06-19-2018, 11:03 AM
Is that not true ?
Not true. There was some rhyme and reason to IH's part numbering system, but R does not stand for "revision". Seen a pamphlet on it once.
Roland Bedell
Buy: Made in the USA
Old 06-19-2018, 11:43 AM
Correct.
BUT, when the part number stays the same, but the end number after the "R" changes that is a revised part. IH used "R1" and "R91" most generally as the beginning of the part number, so revised would continue with 2, or 92.
Old 06-19-2018, 06:33 PM
Rocking416's Avatar
Rocking416 Rocking416 is offline
Thanks for the help everyone! i will order some bearings soon. Than on to the next step removing the old ones! I will try and post pictures
Old 06-19-2018, 06:38 PM
I always take apart, inspect, then order parts. Then you only buy what you need. And, you know what to order.
Old 06-19-2018, 06:56 PM
Rocking416's Avatar
Yes these are the part numbers i need. I dont know what year the timed mower deck is or how to tell. I guess i need to tear it apart? I was just trying to come up with estimate for repairs and place to look for the parts.
Old 06-19-2018, 07:26 PM
From your first post.
I am working on mounting a Cub Cadet Original mower deck on a 70.
So, do you not know if you have a 38" timed deck, or a 38" triangle deck??? Pretty obvious difference.
Your above statement is confusing. Do you mean you have a deck from a Cub Cadet "O" on a 70? Or did you mean you have the original deck to the 70 that you are working on? Either way, it could be either deck...... guess you need to figure out what you have.
Old 06-19-2018, 07:40 PM
bill682 bill682 is offline
He clearly stated it's a timed mower deck from a Cub Cadet Original.
You are the only one confused.
Old 06-19-2018, 07:42 PM
Rocking416's Avatar
Sorry about the confusion. I have a square timed 38" deck from and Original
I need the mower deck spindle/ Mandrel bearings. They are free but i would like to replace them so the deck runs quiet.
Old 06-19-2018, 07:43 PM
You are the one confused.
I did misread his last post. My mistake.
