Cyclops Transmission Adapter
Part number 748-3038. This is a used part and is used on a majority of the cyclops tractors. $60.00 shipped. It is located in Elora, Tn. I will post the pictures later tonight. You can PM me here.
Here is another pic.
Won't fit the Hydro Gear pumps, only the Sundstrand pump.
Yes sir, that is correct. I did not think about that, thanks.
I'm thinking that's one piece I need but haven't torn into my 1782 yet. Although lots of play in that area and shaft has a lot of wobble. Just looked and its NLA? Can you tell me if it has a set screw hole in it? Mine does and I'm thinking it shouldn't but blow out shows a 1/4 X 20 holding it to pump input?
Jeff in PA is making replacements that are longer than the factory part so they engage more of the pump shaft splines.
Found a better a couple better pics of the 2 factory adapters and my design for a comparison.
Thanks Sam. So does the shaft need to be replaced with one that has more spline length? I'm thinking the way mine is wobbling that I may even have to replace the pump shaft but I don't know. Still need to take it apart.
Oh one more thing, is the engine side similar? So when I do it I should get two? Sorry haven't looked yet at parts break down
