Wheel Weight Bolts
I just picked up a used set of 75lb Cub Cadet rear wheel weights for my 2082. I didn't get the mounting bolts with them, they seem to be just long carriage bolts, is there anything special about them? What length is needed for the wider rear wheels on the SGT's, I am assuming the SGT's run a wider rim to fit the bigger tires?
"We don’t stop playing because we grow old, we grow old because we stop playing." |
1/2 inch carriage bolts. Not sure what length you will need for those weights. You could buy long and cut off the excess.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
This is post 1 of 2 with some information on this weight weight kit.
Aaron '83 782 #723927 ****original KT series 1 engine ****added dual hydraulics from older, donor 782 '04 SRC621 '95 Magnum (M18S) spare engine ****spec 24646 ****s/n 2507913316 |
This is post 2 of 2 with some information on this wheel weight kit.
For my set, I actually used the "all thread" method listed in the attachement and it works well. I do, however, have them in all 4 holes. Good luck.
I found over-length carriage bolts at a tractor show, installed the weights, then nipped off the excess with bolt cutters,,,,
It was the only size he had,,, |
I just picked up long carriage bolts at surplus city... they had the 1/2" ones up to 12" in length.
Thanks Guys! This was what I was looking for, I had thought about the all thread method but wasn't sure it was an "approved" method. I like the fact the threaded rod is captured on the rim before you try to wrestle a 75 lb weight on to a couple of wobbly carriage bolts. That tech sheet says 1/2" rod, is that with or without the inserts in the weights? My weights are missing a couple of those inserts and I don't think a 1/2" bolt will fit without pushing those inserts (bushings) out.
