Greg Rozar AKA- CubDieselFan
Old 01-23-2018, 07:48 PM
IliketheRedcubs's Avatar
Jeff, can you pm me? I’ve included a pic of my hydro shaft. Doesn’t look good...
File Type: jpg B1639F56-683C-463C-842A-D654FA5F1062.jpg (18.9 KB, 151 views)
Old 01-23-2018, 07:52 PM
twoton twoton is offline
Come on man, just a little JB weld and it'll be good as new!
Old 01-23-2018, 07:55 PM
PM sent
Jeff
Old 01-23-2018, 08:00 PM
Email sent. It contains 3 pics. If it doesn’t come through email me. Thanks!
Old 01-23-2018, 08:05 PM
Email sent. It contains 3 pics. Thanks!
Got the pics, edit your post to remove your email
I'm wondering if I maximize the splined coupler engagement on the shaft if it would be salvageable?
Jeff
Old 01-23-2018, 10:56 PM
Darryl, I would also change the charge pump seal if you are in it that far. Here is what I use.
I would also check the front ball bushing for wear too.
And while you have the shaft taken loose on one end I would probably also change dynamo/water pump belt. Here are the Gates numbers for the engine belts.
Fan = 6727
Water pump = 7320
If I can think of any other ways to lighten your wallet I will let you know.
Old 01-24-2018, 01:01 PM
Attachment 90509
Fan = 6727
Water pump = 7320
Gee Todd, keep it up and I'll have to do a go fund me page! Seriously, I might rip everything apart if the coupler is loose on the shaft. I'll probably do the whole rear end with axle seals and all. Jeff is going to send me some samples to see if things will fit well. Thanks Jeff!
My hydraulic shop (near me) claims they can still get parts for the pump including the shaft. I'm not sure if I believe them or not... but they say these pumps are used in a lot of different applications. We'll see. The fan belt is new but I'm not sure about the alternator... hmmm maybe I should look into an alternator upgrade...
Old 01-24-2018, 08:40 PM
Splined part mailed today.
Jeff
Old 01-25-2018, 09:14 AM
89cubcadet1772's Avatar
89cubcadet1772 89cubcadet1772 is offline
Jeffs parts are top notch. My pump input on my 1772 had some spline wear aswell when I converted driveshaft. Jeffs coupler engages further onto shaft and is tight and true. How bad did that thing vibrate prior to it failing..wow never seen one that bad. good luck!
89' Cub Cadet 1772
Old 01-25-2018, 09:20 AM
Yes, the shaft is still available. Part #SU-3102989. Only $612.60 from Messicks.
