Greg Rozar AKA- CubDieselFan
Old 03-24-2015, 06:06 PM
Tankman's Avatar
Tankman Tankman is offline
Default 48" 317 SD Deck
What size threads are on the idler arm shoulder bolt?
Just want to be ready.
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 03-25-2015, 06:37 AM
Tankman's Avatar
Think I found it! 7/16-14 nut, lock washer, flat washer.
I'll write it down, forget often at 67+ years old.
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 03-26-2015, 06:39 AM
Tankman's Avatar
The Zerk fitting on this shoulder bolt doesn't unscrew. I can turn it easy enough.
The diagram (and photo) I looked at, Zerk appears to press fit in other than threaded. Is this possible? Never saw a press in grease fitting.
The 48" deck I'm restoring was left outdoors for about a year. Water really ate the carriage bolts to bits, replacing all with new and of course usin' Never-Seez on all threads.
Sure enough, press in. Anyone know the size?
Drive Grease Fittings
Used to avoid tapping costs for a wide variety of applications.The hole size and shank dimensions are for reference only.The correct hole size depends on the type and hardness of the metal. Fittings usually have a serrated shank.
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 03-26-2015, 07:14 AM
Yep they are press in.
Old 03-26-2015, 08:18 AM
Tankman's Avatar
Thanks again Sam. This deck and the rotted hardware is awful.
Thankfully the deck isn't rusted through. Most of the hardware we're cutting off and the grandsons wear goggles while I use the small cut off wheel.
Even though I have a very low opinion of MTD, this Cub is built rather sturdy. Plowing snow, once adjusted, was a breeze. Our only complaint was the inability to angle the blade from the sit down position.
The Cub now lives indoors for the remainder of its' days.
Tankman
'95 CCC 1641
Eastern PA
USMC
