Mower belts
I have 2 107s one deck u1114 and one deck u1116. When I needed a new belt I was told that it 80x3/8. It was very tight and only lasted 2 mowings. So I pulled other belt it was I h 481099 looked this up and it says it is 83x1\2. What size belt is correct?
You make NO mention of the size of the mower deck (ie: 38", 42" or 48").
Sorry both decks are 48"
Houston, we have a problem. I looked on four different sites, parts manuals. mower deck parts guides, and they all state the same. A 107 w/ a 48" mower deck uses a IH-489397-R3 Belt, which is 3/8" x 75.5". Perhaps some images of the Mule Drive, Mower Deck, and belt routing, may add some insight to the problem.
Are you looking for the deck or pto belt.?deck belt is the number you gave 481099 prolly the older type with the large pulley
Well Lew, you could be right. He did NOT specify which belt. I "assumed" that he was looking for the PTO, because most people do.
Sorry I am not being clear. This is the pto belt I am looking for. I am confused. I am going to try the IH belt on the deck that is eating the belts and see what happens
Check your pulleys for alignment, and look-see if the belt is rubbing on something it shouldn't.
Thanks all for responses. I put the IH belt 481099 which part look up says is 83x1/2 on mower that was eating belts and it cut fine and a lot easier to put on . so I think I will order belt from here and hope it keeps working
It is odd a 48" deck belt can be used as the pto belt,whatever works as the grass is growing!
