Timed deck
I'm reassembling the timed deck on my O. Which way does the double pulley on the deck go? Should the smaller diameter pulley be at the top or bottom? I don't have a deck manual, and the parts explosion was of no help to me.
Thanks Bill |
I would assume that the pulley on the left spindle that is driver by the double pulley, would match size for size. In other words, mount it so that the bottom pulley on the double pulley is the same size as the one to the left.
I don't have an "O" and I've never worked on the timed deck, but that just makes sense to me. |
The smaller pulley goes up.
Thanks Guys! I had guessed smaller pulley up when I put it together. I wanted a sanity check because I had to adjust the deck belt engagement pedal part way out of the clevis so it would slide the pulley to the end of travel when disengaging the blades with large pulley down. I am trying to get it to stop the blade drift when the blades are off. Smaller pulley on the bottom would give more slack than the larger one, but the belt seems to catch in the deep V of the pulley and drift anyway. Maybe I have the wrong belt.
John, I checked that out, the left side pulley is a larger diameter than both pulleys on the double pulley. Either way it is a slowing down. I finished replacing the spindle bearings yesterday, How do they look? IMG_3632.jpg IMG_3633.jpg Stupid restoration creep. I stripped it down to replace the spindle bearings, and figured I would paint the underside with appliance epoxy paint. Easy enough right?..... Then I figured I might as well patch a few holes. IMG_3573.jpg Then I figured I might as well fix the left side skid and make a new one for the right side. I just used flat stock I had laying around. IMG_3574.jpgIMG_3575.jpg IMG_3576.jpgIMG_3577.jpg IMG_3603.jpgIMG_3605.jpg I painted it using Rustoleum canvas white and duplicolor school bus yellow. After going through the first can of school bus yellow trying to cover gray primer (never doing that again), I found Rustoleum 2X coverage Gloss Golden Sunset, almost an exact match to the SBY. Bill |
FYI, Rustoleum makes a white sand-able primer that works good under light colors.
147 w/Electric Lift - the tractor that says "Ni!" 147 w/no lift at all - the tractor called "WallE" QA48 deck, 1a tiller with one extension, QA36B snow thrower, QA42 blade and various other bucketraters, grassenators and dirtavators. |
And white primer is definetly on my list if/when I paint the tractor. Bill |
Thread Tools | |
Display Modes | |
