#21
#22
#23
I'll get with you Jeff. Thanks!! |
#24
Jeff, you could make a floating adjustable lift rod n kill 2 birds...?
http://xtrememotorworks.com/Parts%20...sh%20Blade.htm 95.00 plus freight... but it takes care of both front lift applications.
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
#25
The more time I spend with this tractor the more I love it. |
#26
Just a quick question, perhaps notnproper place; but does anyone know if IH ever made an adjustable lift rod?? Because I think I found one unless its a different maker...however It is white, and on a IH push blade....works like a chuck with two threaded pinch tabs...should've took a pic...
#27
The rock shaft arm pictured, am I correct in assuming it installs with the arm/rod connection below the footrest?
On a side note, what are these Sam Mac rear end braces I saw mentioned in another thread? Thanks in advance. |
#28
Rear end braces remedy the issue of the aluminium housing breaking up by the hydrostat. If you dont have them on your 1641, get them. It will save alot of heart ache down the road if you plan to keep the machine.
#29
It was my intention when I bought this tractor to get something that would meet our needs, I didn't want a disposable piece of junk. The 1641 is capable and beyond. I'll have it for a very long time I've been looking into filling the rear tires, rear end braces, and 3 point setups. Braces are next on the list, suggestions on a source? I can't risk breaking this old girl.. |
#30
Got the rockshaft today, nice piece.
