Yup, notice i didnt specify which corner yeah its taller due to the SS front axle of the later cyclops rigs.
To OP. Easiest way to remedy is park the tractor n blade on a level surface install back of subframe on the foot rest bar, then use a hydraulic jack and torpedo level to bring the front of the sub frame up to the point where the BOTTOM of the middle section, (between mold board and sub frame) is perfectly level. Make two extension pieces that bridge the gap between the quick-tach of the tractor and sub frame of the blade. Weld, bolt, duck tape... whatever your skills are. Easy as it gets.
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
I figured the deck would need to be removed, no big deal there. Taking off the sub frame..thats depressing. I assume the rod in the picture is the wrong length lift rod you're speaking of. A rear mounted blade is sounding better and better..
Bill |
That sounds rather simple. First garden tractor I have owned, soon as I have some time I will jump in with both feet. This is all new to me, I have a lot to learn.
In the pic, what is the rod that is clearly to short supposed to attach to?
It attaches to this thingy,BTW your lift bracket on the plow is incorrect.
Looks like this one.
The top picture in Lews post is for the rockshaft, which on your 1641 may be where the depth gage is on the right side of the frame. It is probably occupied by a plastic pointer. The cast piece is around 75.00 I think... I believe XMW makes something that might work.
Lews bottom pic is the correct bracket, but a little ingenuity does not require that specific 1. Id say at this point the rockshaft arm is your main (most expensive), followed by the lift rod, followed by the subframe height, etc... Check with Jeff in PA to see if he can set you up. I have a spare rockshaft arm if he needs to copy it
Thanks for that, I need to have this thing together and complete in 2 weeks to move some stone. Appreciate the help..
