CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Old 04-23-2016, 03:14 PM
SCC-Trim SCC-Trim is offline
Default Rear blade / hitch suggestions
This 1641 I picked up is the first GT I've owned. Aside from mowing, I am going to need to do some light grading. Mainly stone, but possibly a little dirt. The largest stone would be #2's. The cub doesn't have a hitch, so I am starting from scratch here. Any advice you guys could throw my way regarding hitches and a blade that could handle this task is appreciated. Not looking to spend a fortune on this stuff, lots of demands on me presently.
It did come with a front blade also, but honestly not certain if its even for the 1641? Thanks in advance guys.
Old 04-23-2016, 03:22 PM
You would have to put a 3pt hitch on it for a rear blade. The front blade is the best cost effective choice. Lets see some pics of it.
Old 04-23-2016, 04:51 PM
Think this has potential?
Old 04-23-2016, 05:04 PM
the potential for tetanus. we'd need some better pics to determine if it will fit.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-23-2016, 05:13 PM
Ha! Truth, stepping out for the night. I'll do better tomorrow. Thanks!
Old 04-23-2016, 05:54 PM
I think it will work. It's not the one that was actually made for a cyclops, but should fit. Have you tried to install it? There was a minor difference between the WF blades and the ones for the cyclops series. You can make the WF blade work.
Old 04-24-2016, 07:50 PM
A couple pics after mowing today.
Old 04-24-2016, 09:22 PM
It will work. But, you have to take the deck and subframe off.
Old 04-24-2016, 10:21 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Yup! The only thing that wont be quite right, is when you angle the blade one corner will be in the air... just a difference in frame height.
Easy to correct, or just live with it
1- 1200 in pieces
1- 1864 in pieces
Old 04-24-2016, 10:24 PM
I thought the cyclops were a little taller? Wouldn't the back corner not touch the ground?
Like you said, easy to correct.
Oh, if it has a lift rod, it likely won't be the correct length. JeffinPA makes them on this site. He has an ad in the "Parts sources" section.
Thread Tools
Display Modes
