Greg Rozar AKA- CubDieselFan
Old 08-22-2014, 11:55 PM
bocephus1991's Avatar
Something I was wondering , do they make a forged steel rod for kohlers? Just curious gonna use a regular aluminum rod on mine.
Brian
Old 08-23-2014, 01:11 AM
Originally Posted by dvogtvpe View Post
you do need to rebalance the rotating assembly
When doing an insert you mean?
Not to my knowledge. I would think that would really throw the balance off..... like A LOT!
Old 08-23-2014, 07:54 AM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
when putting an aftermarket rod in.
Old 08-23-2014, 08:06 AM
austin8214's Avatar
What after market rod are you using that is so heavy it requires rebalancing the crank?
Old 08-23-2014, 08:25 AM
dvogtvpe's Avatar
any of them are heavy enough that the rotating assembly needs to be balanced.
Old 08-23-2014, 04:54 PM
Don, with a .10" under rod on a k301 do you need to rebalance anything? Or just the larger engines?
Brian
Old 08-23-2014, 08:07 PM
dvogtvpe's Avatar
when I say aftermarket rods I' referring to the billet rods by Kerber, Midwest, vogel ect
stock motors are so far out of balance I don't think the insert affects much but I think its a good idea
Old 08-24-2014, 01:11 AM
That's what I thought with stock engines the way they shake and carry on not be well balanced to start with. I fig the balancing was more for pulling engines running higher Rpms .
Brian
Old 03-09-2018, 06:39 PM
dodge trucker dodge trucker is offline
reviving an ancient post
Anyone have a part number for an insert for a K301/K321 rod that is 0.020" under?
nevermind/found it. turns out even after I got the PN it was a bit tough to locate.
Old 03-12-2018, 12:38 PM
I just ordered a set of 4, 0.020 inserts from eBay to do this exact job,. I have 2 used Kohler rods at the machine shop to have them bored for an insert as we speak. I found out the application needed, can go std all the way to 0.060 under. Let's see what he charges me to rework the rod, will make future rebuilds a piece of cake, can use the same rod for any undersize I want. I have a k321 in machine work right now, with a pair of k341s and a M14 ready right behind this one for the machine shop.
