Greg Rozar AKA- CubDieselFan
Old 08-16-2017, 01:31 AM
EarlJ's Avatar
EarlJ EarlJ is offline
Default 1782 issues
I've been having a few issues with the 1782 aside from the driveshaft bearings. First it's real slow in reverse, this has been a slight issue since I bought it. I'm thinking maybe hydro fluid and filter and possibly trunion is out if adjustment. Next it's started this after the peacock plugged up. I repaired that issue and replaced the lift pump with one slightly more capable. That said if I'm mowing and shut it down or it stalls when I fire it back up it will stall when I engage the pto and act like the battery is dead. Let it cool for 20 or so mins and its fine.
I mowed this evening and never shut down just disengaged the pto and had no issue. I did notice the temp light came on so I decided it was time for rest and a bath. I pulled the dirt screen and it was filthy as was the radiator. I cleaned the screen and pressure washed the tractor trying to remove the years of grease and grime from everywhere. I have a hydro fluid leak behind the dash and need to find where that is.
I know I have a lot of info and queations worthy of another post but this is my first running smoker so what I learn here I can apply to the 782d basket case.. Thanks in advance..
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 08-16-2017, 07:30 AM
There is a service bulletin to fix the slow reverse on the cyclops tractors, I know Lew has that info so maybe he will chime in or you could send him a pm.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-16-2017, 11:28 AM
Earl
Just a heads up I put temp gauges in my 2182's and 1782. They all got hot and never had the light come on. I suggest that you put at least a temp gauge in it and do not trust the light.
Old 08-16-2017, 03:20 PM
V30crewcab V30crewcab is offline
when I got my 1782 I had issues with it shutting off intermittently, ended up being the shutoff solenoid needed to be adjusted, I had to bend the rod as it was holding tension on the shutoff solenoid and not letting it move fully to the on position, and any little bump would kick it off. take the lever loose with it in the run position and make sure it can fully extend.
I've also noticed the supers seem to have a slower reverse. both my 1782's are that way. I haven't redrilled the linkage hole yet to try that.
http://onlycubcadets.net/forum/showthread.php?t=47908
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 08-16-2017, 11:16 PM
EarlJ's Avatar
Earl
I plan to do that. I have a nice gauge purchased for a truck my kid bought but sold prior.
I will definitely pm him, thanks for the heads up on that.
Mine is adjusted correctly, I've watched it to be sure what it's doing. That said after doing the major bath I found the power plug is a plastic plug on one side and splice blades on the other. My suspicion is as the tractor heats up the tape holding them in place expands loosening the connection. Once cooled, it shrinks back into place. I'll be at the parts house tomorrow searching for a male and female plug set up and properly splice them in.
Old 08-22-2017, 07:44 PM
EarlJ's Avatar
Hey thanks for that link too. I didn't see it at first. It has a ton of bulletins that apply to these tractors.
Thread Tools
Display Modes
