Trunnion and controls
Hi all, I know trunnion springs and adjustments have been talked about before but I have a few questions. I've just now dug into mine. My 1812 was never "right" since I got it but I've lived with it, mainly because I've been busy. Got the fender pan off and someone has put some washers in between the springs and pins. I'm going to order new pins and springs. Otherwise looks ok, not elongated or worn. Biggest concern I have is the "damper spring plate" as cub calls it is loose on the shaft coming out of the pump. Not horribly bad, but does have some slop. Should I get a new one? Or try to shim it? Let it go? Thanks in advance.
Everyone of mine have a little slop. Yeah I know one's "a little" may be a lot to another. If it's bothering you, shims would be the best, and cheapest way to snug it up.
I would be more concerned with the trunnion, springs and caps...
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
Thanks Zippy.
I ordered springs and pins from the dealer-actually they had them there. Had some stuff to get from xtreme motorworks so I ordered the trunnion repair thing he had. I can live with a little slop on that bracket. We'll see what happens |
Tags |
trunnion |
Thread Tools | |
Display Modes | |
