I have all heat shields and foam. Muffler and heat shields from a 1862.
I swapped my engine a couple of years ago and have no heat issues, I run the side shields all the time. My kid uses it in his lawn mowing business. She's got a lot of hrs.
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
I probably found the root of the issue. I remember seeing a mechanic check for exhaust leaks with a rag over the exhaust pipe. I did that with this tractor and it's blowing air out between the support piece and the muffler. There's a crack there.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower IH Cub Original with deck #2 cart GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck |
If you don't have the space between the firewall and the blower intake sealed it will re-circulate hot air. This is what I did when I re-powered a 1210 with a 16HP Vanguard.
I decided to go ahead and drop my good vanguard in this tractor and salt away the CH18 (my original plan for this engine anyway) for my 1864 someday. The Kohler just seems to make it hard to steer, i noticed that when I tried the CH18 in a 1641. The space between the firewall and engine is such that I have room to make a solid shroud just like yours rather than using a thick piece of foam.
I think I would put some foam in and drop the lower shield out and try it for a little bit. might just cure the problem. needs to be able to suck air from the bottom since theres no grates in the side panels like the cyclops have.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't! 72 scout IH 404 tractor |
It might but I'm already a few steps ahead of that, because I found a crack in the muffler blowing hot air back over the engine. I don't feel like replacing that muffler right now. I am going to drop that shield out and use it for a pattern to make one out of perforated sheet metal to put in there along with a cowl like Sam showed.
I used roll plastic, got it from a race car supply shop.
You went through all that work, and now you're going to swap motors short of just adding some foam strips? You must like work.
Hey.... the other motor is going to need some kind of seal or shroud and the lower panel removed also. Seems to me it would be a lot easier to just fix the motor already installed in the tractor. |
Seriously though, I had more than one issue with that motor. Mainly it needed another muffler and I melted the air filter cover, and partially melted the valve cover on the one side. It was hot enough that I pushed on it and made an imprint. The air filter cover was a PIA to get on with the firewall there anyway. The Briggs fits much nicer so I will work with that now. It's not a big deal to switch engines. Just a few wires here and there and a few bolts. What's the big deal?
Different drive shaft length also. Hot setup is to use a 1641 or 1440 shaft with the Vanguard.
Thread Tools | |
Display Modes | |
