Greg Rozar AKA- CubDieselFan
Old 08-08-2017, 03:37 PM
Pequeacubs's Avatar
Pequeacubs Pequeacubs is offline
Default Trunion in 1810
the truion and springs are jack hammering when going from forward to reverse check all the linkage and nothing is worn. looking for any ones 2 cents thanks
107 w/ 75lb IHC wheel weights 3pt. hitch spring assist lift.
1810 w/spring assist and brinly cat.0 3pt hitch w/A frame adapter and sleeve hitch now an 1811 cab and 551 blower
1000
42" spring tip snow dozer blade,qa36a snow thrower,#1 tiller w/1 ext., brinly 10"moldbord, 3pt.cutivator,brinly disk,#1 trailer #4 trailer, 2 sets of Ih weights
windbreaker soft cab,qa42" snow thrower
my grand fathers 67' j.d.110h with brass tag 6 way snow/dozer blade
67' WH lawn ranger
Old 08-08-2017, 03:42 PM
CubDieselFan's Avatar
Can you snap a picture of the truion?
Old 08-08-2017, 03:44 PM
Pequeacubs's Avatar
i currently have the tractor back together so not able to post a pic.
1000
67' WH lawn ranger
Old 08-09-2017, 08:01 AM
Explain "jack hammering".
How long since you changed the fluid and filter in the rear?
Old 08-09-2017, 04:13 PM
Pequeacubs's Avatar
The jack hammering is coming from the tunion springs i just put new ones in. the trunoin lever is the part hammering back and forth
1000
67' WH lawn ranger
Old 08-09-2017, 04:16 PM
Pequeacubs's Avatar
i ma changing the filter and fluid next week to see if that helps
1000
67' WH lawn ranger
Old 08-09-2017, 06:57 PM
How bad was it before the repair?
Old 08-19-2017, 09:37 PM
Pequeacubs's Avatar
i just changed the rear oil and filter just last night tested tonite and still have truion spring chatter from forward to neutral and neutral . there was a layer of pinkish waxy residue in top of the trans housing. i am at a loss now
1000
67' WH lawn ranger
Old 08-19-2017, 10:32 PM
Can you take a video of this, post it to a hosting site (like YouTube) and give us the link? Either you aren't explaining the problem in a way we understand, or you have an issue we haven't seen, or you have a normal issue you think is not normal. Thanks.
Old 08-19-2017, 10:34 PM
Pequeacubs's Avatar
i will try to get a video tomorrow if the weather cooperates
1000
67' WH lawn ranger
