149 & #1 Tiller belt
Any one using a gates AX144 belt on a 149 & #1tiller? I saw that some one was using it with a Cub 125 and wondered if it will fit my outfit. All input appreciated.
My local NAPA can't cross reference the IH-549250-R1 part #. Have a great day. Bob |
The IH-549250-R1 is the correct belt which is by dimension: 13/32" x 143-7/8".
A "section A" belt is over 1/2" in width. It would seem that it would not ride in the Pulley grooves correctly. BTW....the IH-549250-R1 belt is still available from CC.
I'm using an AX144 on #2 tiller and a 129. I was under the impression there was not much difference in the #1 and #2 gearbox/mounting setup. The 1/2" belt does not seem to ride high enough in the grooves to cause any problems. Everything is a little thinner/smaller these days it seems.
Thanks for the responses. I know that belt is still available. Would not be using the tiller all that much and am trying to save a little money. If it works on a 129 & #2 tiller, it should work on what I have. Thank you both for your help and have a great day.
Bob |
